UK Vintage Radio Repair and Restoration   Vintage Radio Service Data
Register FAQ Forum Rules Calendar Search Today's Posts Mark Forums Read
Old 30th Jun 2007, 05:40 PM   #1
neil29
neil29's Avatar
Default Philips G11
I've been having a look at the set I got from Mike last week, and he said it had frame collapse.
Even though I've changed the TDA 2900, it still wont co-operate with me; also it keeps blowing two fuses on the line output panel (the 500 milliamp and the 800 ones).
Any suggestions most welcomed.
thanks,neil.
neil29 is offline   Reply With Quote
Old 30th Jun 2007, 06:32 PM   #2
Michael Maurice
Michael Maurice's Avatar
Default Re: Philips G11
I wonder if the supply rectifier diode is s/c?
Also change 680uF caps that decouple the supply.
Michael Maurice is online now   Reply With Quote
Old 1st Jul 2007, 01:36 PM   #3
coil1234
Hello Neil,
Glad the G11 has found a good home, I was initially interested but only for spares.
Looking at my manual for the "700 Series" the supplies through the 500mA (FS151) & 800mA (FS143) fuses originate from the same winding on the LOPT and are rectified by D138.
FS143 feeds LT3 (37 Volts) to the TB panel and is smoothed by C144 on the Line Scan Panel.
FS151 feeds LT4 (37 Volts) to the IF panel where it is smoothed by C47, LT4 goes via Fusable resistor R46 on the IF panel, my diagram also shows this supply fed out from the IF panel on pin 1 of connector 5Z (some sets only!)
You may have multiple faults, however the obvious fault to cause both fuses to blow would be the rectifier diode D138 short circuit (as sugessted by Michael Maurice above).
Hope this helps in restoring another of these excellent sets, good luck
Mike A
coil1234 is offline   Reply With Quote
Old 1st Jul 2007, 01:37 PM   #4
Sideband
Sideband's Avatar
Originally Posted by neil29 View Post
but even though ive changed the TDA 2900 etc it still wont co-operate with me,
Hi Neil. I hope that is supposed to say TDA2600! I suggest you also try the chip holder. These were notorious for giving trouble and make sure you have fresh heatsink compound between the chip and the heatsink. I should also mention the importance of making sure the large 470UF smoothing cap on the power supply has been changed. These used to arc and cause all sorts of problems including a cracked CRT neck!
Rich.
Nostalgia is a thing of the past!
Old 1st Jul 2007, 01:43 PM   #5
Dr-Watts
Dr-Watts's Avatar
The chip should be a TDA2600!
If the wrong chip is fitted, that could explain your problem!
Take the chip out and try again with new fuses fitted, if it's the chip, the fuse will stay intact --- Hopefully
These chips were pretty unreliable and blown fuses were regular when the chip went faulty.
The chip holder could also be suspect !
Also have a look at...
If the voltage at pin 16 of the TDA2600 is much less than 19V, check C2099 and C2100 both are 1000uf.
Also have a look at C2060, C4029 and R2066 as dry joints are very popular here, ( just like everywhere else on this chassis ! )
It's certainly worth sticking all these caps on a meter and checking their worth.
I'd also check the wiring harness, just in case it's rubbed through somewhere near the frame stage. (Another forgotten favourite !)
I loved the G11, when I started as a apprentice in Luton I did G11 after G11 !
God only knows why they were so popular in sunny Luton.
A TDA2600, a handful of 1N4007s, a couple of BY223s (the funny red ones )and a BU208A and you'd be able to get any poorly G11 in the field.
Oh, and a smoothing cap, of course. I've still got the circuit if you need a copy...
Hope this is of use to you.
Dave W
Do you have the scope to be a TV repair man
Dr-Watts is offline   Reply With Quote
Old 18th Jul 2007, 06:17 PM   #6
neil29
neil29's Avatar
One thing I forgot to ask about was D138 on the line output panel.
I don't have any exact replacements, what would be the next best one to try?
cheers neil.
Old 20th Jul 2007, 03:23 PM   #7
Welsh Anorak
Welsh Anorak's Avatar
Hi
I'd suggest a BY299 as it's happy with flyback pulses and will pass 2A happily.
Unfortunately it's not red....
Glyn
Last edited by Mike Phelan; 3rd Jun 2008 at 07:42 AM. Reason: Changed from BY228 as per Glyn's request
Welsh Anorak is offline   Reply With Quote
Old 28th Jul 2010, 02:08 PM   #8
neil29
neil29's Avatar
Well ive been tinkering with this set again . and the picture below is the result . there is no sound nor can the brightness be turned down. any ideas??. thanks neil. ps this is not the set that i fixed fairly recently..
Old 28th Jul 2010, 04:44 PM   #9
Red to black
Red to black's Avatar
Here is a list of stock faults.
Baz
It's not fixed unless there are screws leftover!
Red to black is online now   Reply With Quote
Old 29th Jul 2010, 06:38 PM   #10
Hybrid tellies
Hybrid tellies's Avatar
That list of stock faults is brilliant. But looking at your picture it looks like you have excessive green drive. I would start by checking voltages around the green output stage, I would expect the voltage on the green cathode of the crt is a bit on the low side. Hopefully this is due to an output or driver fault. As for the no sound fault check the voltages around that output stage which I think is an ic on this set.
Simon
BVWS member
Hybrid tellies is offline   Reply With Quote
Old 30th Jul 2010, 12:16 PM   #11
Welsh Anorak
Hi
The sound fault is often the fusible resistor that feeds the output pair on the IF panel springing open for no reason.
Glyn
Old 31st Jul 2010, 09:28 PM   #12
neil29
neil29's Avatar
Well ive been at it again and swapped the if panel and decoder. and the sound has come back and i no longer have a green tint to the picture. but there is still no picture of any sort even after checking parts with the fault list above. also when i put the teletext on the set seems to take offence and the raster does what i can best describe as pulsate as if its about to collapse. well im stuck as usual..any ideas. thanks neil.
Old 31st Jul 2010, 09:45 PM   #13
Red to black
Here are 2 more faults listed for you.
(I no longer have a diagram) would anyone care to post one?
1)dark pic & no colour Ht pulsating : IC2510
2) No video : D4090 S/C (zener 4V7)
Have you tried temporarily disconnecting the text board?
Baz
Ps. sorry these faults are already on the list I posted earlier
Old 3rd Aug 2010, 11:00 AM   #14
gec2110
i think that there is fuse gone on the Line timebase panel
the 200volt line is probably missing have a manual at home
and a pye studio fault guide
1 check the fuses and the condition of the line time base before looking else where
the 12volt regulator could also be faulty on the if panel
if it is text? is there a voltage which drives the RGB from the text panel which is missing
or has a fuse lost its life somewhere
gec2110 is offline   Reply With Quote
Old 3rd Aug 2010, 11:10 AM   #15
gec2110
Thsese G11 were good and i liked them very much but why so many stock faults and some poor quality componets the smothing cap and the frame ic with that nasty low profile holder i thought that they had learned the lesson from the really bad awful G9
G11 not the best set of all time but it is pretty hard to beat
and i love them
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All information and advice on this forum is subject to the WARNING AND DISCLAIMER located at http://www.vintage-radio.net.
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©1997 - 2010, S&P Technology.
FIT Online Fashion Store - Now Open!
