Old 21st Sep 2007, 4:32 pm   #1
oldeurope
oldeurope's Avatar
Smile Making a Triode Loftin White
after making the triode coupled RIAA preamp
https://www.vintage-radio.net/forum/...ad.php?t=18326
I decided to modify my RL12T15 triode amp for Loftin White.
http://rl12t15.blogspot.com/
I thaught this topologie is Loftin White:
http://bp0.blogger.com/_oCEpds9YoPw/...ftin+White.png
The thing I don't like in this circuit is the the cathode decoupling cap for the output triode.
I searched for a solution that makes it possible to eleminate the coupling cap
and the cathode decoupling cap and came up to the following solution:
http://bp0.blogger.com/_oCEpds9YoPw/...+schematic.png
This circuit solves all problems and compensates hum and signal voltage dropping at C2 as well.
Now I was very curiously whether someone did something similar.
I searched in the www and found nothing similar except this one:
http://www.mindspring.com/~mjh850830/loftin-white/
You can download the originals from Loftin and White there:
http://www.mindspring.com/~mjh850830...e/article.html
I am very impressed about the work of Loftin and White.
Quote from Radio News Feb. 1930:
"Forget Former Conceptions on Audio Amplifier Theory"
There are two people coming to show the world how to build up a perfect valve amp and it is totally ignored and misunderstood.
Note this Quote from Radio News Feb.1930:
"A condenser, C2, of about 1 microfarad is needed to form a local signal circuit in the output circuit including association of any suitable loud speaker as indicated."
http://www.nutshellhifi.com/library/Tube_Fest_Talk.html
Where is Loftin White here?
Elliano Ultrapath- an incoplete Loftin White?
And Mullard's 3-3?
http://vintageradio.me.uk/amplifier/mullard33_2.jpg
What do you think?
Kind regards,
Darius
oldeurope is offline
Old 23rd Sep 2007, 6:20 pm   #2
daviddeakin
daviddeakin's Avatar
Default Re: Making a Triode Loftin White
Hmm, it seems that you have eliminated the cathode cap by introducing positive feedback from the power valve cathode to the PC86, to make up for the lost gain. An interesting solution, though I can't say I would use positive feedback in any audio amplifier- it seems to risky.
I would simply have used LEDs to bias the PC86- no need for any capacitors at all!
daviddeakin is offline
Old 23rd Sep 2007, 6:44 pm   #3
screengrid
Ah, the old Loftin-White..............
I breadboarded one a few years ago, and; at the time; found this article by Broskie.
http://www.tubecad.com/may2000/page17.html
I didn't have any trouble with mine, no matter how much I tried to destroy it!
screengrid is offline
Old 24th Sep 2007, 8:53 am   #4
oldeurope
oldeurope's Avatar
Smile Re: Making a Triode Loftin White
Hi David,
thanks for your reply.
This is not any positive or negative feedback. There is no signal voltage "lost" at the cathode of the RL12T15. Please note this aspect:
Have a look at the Western Electric repeater amplifier. There is no need for a cathode decoupling of the output valve. Same situation in a Loftin White arrangement.
Imagine C2's capacitance is infinite and it is charged, or say it is a perfect cap like a voltage source. In this case there is no signal voltage drop at the cathode resistor. Loftin White compensates the influence of the last smoothing cap to the signal with Chb too. Is this well explained?
Chb makes the triode output floating on the cathode level of the output valve.
This makes it possible for me to replace the Loftin White input tetrode by a triode.
The supply voltage for the PC86 is much higher (ca.550VDC) than the anode voltage (ca.100VDC) and (!) 220K Ohms divided by 560 Ohms is much higher than micro. Thus a cathode decoupling is not neccessary here. An LED is a non linear component. I don't want to use these there.
Kind regards,
Darius
Old 24th Sep 2007, 9:30 am   #5
oldeurope
oldeurope's Avatar
Exclamation Re: Making a Triode Loftin White
there are lots of so called "save Loftin White" in the www
nothing to do with Loftin White,
but a solution for a problem that does not exist in a well designed Loftin White.
Loftin White is safe.
Imagine what happens to an output valve in a set using a leaking coupling cap.
Caused by the low resistance of the cathode resistor the current increases very much.
I think you know this problem from the vintage sets.
Loftin White protects the valve.
A Loftin White is save and does not need a choke.
Please have a look at the links in #1
Kind regards,
Darius
Old 24th Sep 2007, 10:53 am   #6
oldeurope
oldeurope's Avatar
Thumbs up Re: Making a Triode Loftin White
#5
Please note that the PC86 has two anode pins. This offers a nice feature, it makes a current shut down for the output valve possible. Have a look at
http://RL12T15.blogspot.com
The underlined words there are links to websites and pictures.
This pic shows the connection of the PC86:
http://bp3.blogger.com/_oCEpds9YoPw/..._von+unten.JPG
And a surge arrester protects the output transformer from arcing.
http://bp1.blogger.com/_oCEpds9YoPw/...ftin_White.JPG
Kind regards,
Darius
Old 26th Sep 2007, 8:00 pm   #7
daviddeakin
But in your circuit, C2 serves exactly the same purpose as the original decoupling cap! It decouples the cathode to the HT, rather than to ground. I can't see how that is an improvement, because you now introduce HT noise directly into the cathode.
You also have Chb, which is yet ANOTHER decoupling cap (decoupling via C2), so you appear to have made your problem of capacitors worse, not better.
And LED may be a non-linear device, but compared to an electrolytic capacitor is is VERY linear. I would certainly prefer LEDs before electrolytics.
Old 27th Sep 2007, 8:21 am   #8
oldeurope
oldeurope's Avatar
Hi David,
C2 does not serve exactly the same purpose as the original cathode decoupling cap.
C2 serves the same purpose as the B+ Capacitor in the "Conventional SE"
have a look at http://www.nutshellhifi.com/library/Tube_Fest_Talk.html
Please try to understand what Lynn Olson explaines there!
C2 in Loftin White serves exactly the same purpose as the cap in the Western Electric (output). There is no need for a cathode decoupling cap.
Importand: In a Loftin White it is forbidden to decouple the cathode of the output triode
with a capacitor in parallel to the cathode resistor!!!
Chb is not a decoupling cap in my application.
Please not that there is 30K Ohms (!) in series with Chb. This is much more impedance than the cathode resistor(s) have.
Thus Chb is not able to decouple there.
In my application Chb makes the driver triodes anode floating.
This makes it possible for me to use a triode instad of a tetrode (or pentode)
in my Loftin White topologie.
Have a look at the Western Electric (repeater amplifier) again.
(scroll to the middle) http://www.nutshellhifi.com/library/Tube_Fest_Talk.html
There is a cap (0.22uF) it makes the interstage transfromers secondary floating.
Do you understand now what is going on there?
At last the LED. Its non linearity causes harmonics, "non linear destortions". The result is an "LED sound" if you like this it is ok. An electrolytic changes its impedance with the frequency this gives "linear destortions". Thus the resistor is the best choise here and it causes no losses in my application as explained in #4.
Kind regards,
Darius
Old 28th Sep 2007, 4:11 pm   #9
daviddeakin
Hi David,
C2 in Loftin White serves exactly the same purpose as the cap in the Western Electric (output). Darius
This is not true.
In the Western Electric, the output transformer is connected in PARALLEL with the valve, and is coupled to the cathode via that capacitor.
In your chematic,
the output transformer is connected in series with the anode in the normal way, and C2 decouples the cathode directly to the steady HT supply voltage, which, as far as AC is concerned, is exactly the same as decoupling to ground.
Old 28th Sep 2007, 4:27 pm   #10
oldeurope
oldeurope's Avatar
This is not true.
In your chematic,
Hi David,
do you agree, that it does not make a difference on which end of the output transformers
primary the current source is connected in the Western Electric?
(Except that parallel feed does not make a DC current in the output transformer, of course.)
Kind regards,
Darius
Old 3rd Nov 2007, 4:40 pm   #11
oldeurope
oldeurope's Avatar
Thumbs up Re: Making a Triode Loftin White 300B
proudly present the ECC83 300B schematic
http://rl12t15.blogspot.com/2007_11_01_archive.html
Thanks for looking,
Darius
Old 4th Jun 2008, 5:40 pm   #12
sheldone
In your chematic,
I know that I'm late to the party here, but Darius, through the DIY Audio forum, got me interested in the Loftin White design. So, out of curiosity, I started looking around the net. Turns out to be very few actual Loftin White designs, which got me more intrigued. I eventually came across this thread, only to find Darius here too. One man on a lonely mission, but I think he's on to something. To my inexperienced eyes, this seems an elegant design. And it's a bit subtle, until it isn't.
"C2 decouples the cathode directly to the steady HT supply voltage, which, as far as AC is concerned, is exactly the same as decoupling to ground" - This would be an accurate statement, if the power supply had low AC impedance to ground. But in that case you have to have two capacitors - the final power supply cap to ground, and the bypass cap to ground (or to B+). There is only one capacitor in the LW.
In the LW, the inductor in the LW is not followed by a Cap to ground, so there is no low impedance path to ground. Instead, the AC current flows in a closed loop, that's floated above ground by the cathode resistor. In fact, you could replace both the power supply inductor and the cathode resistor with perfect constant current sources, so the AC impedance to ground is infinite, and the circuit still works.
Now, the input grid is referenced to ground, but the output loop is not, as described above. As the output loop floats up and down due to power supply ripple, it generates a voltage potential between the input plate and output grid. The steady state power supply ripple is, of course, from imperfect filtering of the rectified AC. But there is also a dynamic ripple component that is caused by imperfect response to transient current demands, which will also cause the output stage to float up and down. The series RC, from the output cathode to the input cathode, injects the a portion of this ripple to input cathode, which generates an antiphase signal at the input anode, to cancel the ripple component. So this is not feedback as it does not compare the input waveform to the output waveform, it only subtracts the ripple component. It will not affect harmonic distortion or bandwidth or phase response. Pretty cool, no?
Sheldon
sheldone is offline
Old 6th Jun 2008, 9:45 am   #13
oldeurope
oldeurope's Avatar
Smile Darius Loftin White
Welcome Sheldon,
thank you very much for your excellent description.
Sheldon
Please note that it is necessary to add a capacitance from the supply rail to ground
for eliminating the influence of the output transformers primary-->secondary capacitance.
It is the 4,5µF in the PC86 RL12T15 Loftin White schematic.
Kind regards,
Darius
Old 7th Jun 2008, 9:29 pm   #14
sheldone
Thanks Darius. I overlooked that issue. How do you size that capacitor? By scope or calculation, then confirm? I also notice what looks to be a zobel across the primary of the OPT, but it's hard to read the values. Again, are those just done by looking at ringing and tuning accordingly?
Sheldon
sheldone is offline
Old 8th Jun 2008, 9:49 am   #15
oldeurope
oldeurope's Avatar
Thanks Darius. ... How do you size that capacitor? ... I also notice what looks to be a zobel across the primary of the OPT ...
Sheldon
Hi Sheldon,
the 4µ5F was just there from the old circuit at the beginning of the blog.
Do you mean the protection against arcing at the primary?
Click on the link "Funkenstrecke" at the end of the blog.
Kind regards,
Darius
http://rl12t15.blogspot.com/2007_09_01_archive.html
(use a website translator,
underlined words are hyper links.)
Old 8th Jun 2008, 9:10 pm   #16
sheldone
Ah, spark gap. That symbol is new to me. Not something I've noticed on audio amp schematics before, though it seems like a good idea. Is it more necessary in a design like this, because of the cap in the current loop?
Sheldon
sheldone is offline
Old 9th Jun 2008, 8:29 am   #17
oldeurope
oldeurope's Avatar
#16
Hi Sheldon,
every output transformer should have some kind of protection against over voltage, shouldn't it?
Kind regards,
Darius
Old 9th Jun 2008, 3:57 pm   #18
sheldone
#16
Some more than others, I suppose. But it can't hurt, in any case.
Sheldon
sheldone is offline
