HRO help
I have been trying to figure out a problem with my HRO-5 (was restored by another but not able to obtain assistance) but not getting very far.
The HRO-5 appears to have 'lost the secondary grid voltage' on the 6K7 valves which is my simple description but I cannot seem to locate the fault. This is obtained by division of the input voltage B+ but the R all seem to be fine so scratching head ... (I could wholesale replace them all just in case but seems a bit like overkill) I have managed to check the voltages on the pins on both my faulty HRO and a working one (at RAF Duxford) and pin Pin4 ( Screen Grid?) on many of mine are at 0V (2nd IF V6 (6K7), 1st IF V5 (6K7), 2nd RF V2 (6K7), 1st RF V1(6K7)) when on the working HRO-5 are at about 138V DC. And Pin 5 & 8 are at 0V on V5 1st IF (6K7) and V2 2nd RF (6K7) whereas on working are at 4.33V DC. Anode voltage on these valves are all c230V so the B+ is working. R10 is fine and is 15K R32 appears to be fine 1K (168V at R30 end, 158V at other feeding R10) R30 is a 2K2 1/4 watt and is fine. R11 is 3K (a 2K7 is fitted and was there when I got the set) R15 is 33K One end of R10 is at 158V DC the other connected to pin 4 V6 is at zero volts. I tried with all the 6K7 valves removed V1, V2, V5, V6 but no change in the voltage values. Pin 6 of V7 which comes from the same B+ source initially is at 168V through R18 which is a bit high at 53K not 47K. The AF stage V9 is working fine as I can inject a signal into it and get plenty of amplification. Anyone got any idea what might be the problem or suggestions? 72 Dom M1KTA |
Re: HRO help
Check if there is a screen decoupling capacitor gone leaky do you have a circuit diagram. Mick.
Check if there is a screen decoupling capacitor gone leaky. Do you have a circuit diagram? Mick. |
Re: HRO help
Hi Dom, sounds like a short from G2s to earth, maybe C23, but R10 would run rather hot!
Peter |
Re: HRO help
I might go and grab the digital camera if not clear. I don't have any 400V 0.1uF but I have a couple modern 0.1uF 600V versions... right now I want to get it working, will sort the proper replacement later. 72 Dom M1KTA |
Re: HRO help
I have a very bad photo copy of a location image that sort of helps to ID the components. 72 Dom M1KTA |
Re: HRO help
Re: HRO help
This is the HRO-M version but I 'think' the circuit is the same for the HRO-5 which I have. You also suspect C23 on far left of the diagram the grid voltage bypass? 72 Dom M1KTA |
Re: HRO help
Thanks... C23 replaced with a modern Sprague 400V 0.1uF and the radio springs to life ;-)
I think I might take the time to make up some look-a-like 0.1uF capacitors as I have a number of vintage caps that I could replace the insides with modern versions. Thanks to all that read the post, responded and the pm's. 72 Dom M1KTA |
Re: HRO help
This might help someone else...
The heater indicator bulb had also blown, small bayonet type just to the right of the tuning dial and suffice to say a pig to get to it and replace. Anyway I replaced it with something I had to hand a simple car side and tail bulb. RU233 12V 4W BA9 cost 60p. The fun bit was getting the old one out and replacing the new. 1/4" bore rubber hose (like the sort used in school science labs with a Bunsen burner), snug fit over the new bulb allowing it to be fitted, once locked into position the rubber tube can be rotated off. 72 Dom M1KTA |
